Just put my car in storage... Pretty happy..
Went for a drive around before hand, was pretty good (second drive after tune) but was taking it pretty easy, worried about police/double demerits...
The misses thinks the car is faster now haha...
The main thing is the torque.. It felt like it was trying to break traction in first under acceleration.. Pretty sure it didn't used to do that ha
storage? :O
why would you do that to a masterpiece like yours?
Off to Vanuatu for a friends wedding
I'm at the check in now and the friends are broken down on the freeway
If they miss the flight at least we get a nice holiday still hahaha
Ant good result on the car
At least it's one less thing to worry about at home with the car safe
And yes it will get angry being looked up so will have to drive it like ya stole it next time LOL
Main reasons for storage is space and driveway issues..
Live in a unit with a double garage and own 3 cars... Got coilovers coming in a few weeks and only just get out of the driveway as is.. And ever since I bought it I've wanted to get it sitting right, out of 4wd spec ha
Hmmmm, park the daily on the street GTR in the garrage.
Yea I do that, but I still have the problem with the driveway, and being a unit complex can't really fix it unfortunately...
I will still be driving it as frequently! If not more so!
Got 9 people in my house tonight. Family is up.
Got the blokes working on my yard while I have a beer.
9m cube of soil coming tomorrow to try and fix my shitty lawn.
Ant did they get you a spot next to the power??
Need to catch up soon brah. Watching the game tomorrow?
Yea buddy storage is all good, different place but.
Yea going to the bay to watch the game.. Pretty buggered from last night though ha
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
