Nice man :) glad it's sorted. Where's the new place??
So buggered. Just got 6 cubic metres of soil delivered to my yard. It's shoveled, smoothed, to f**k off high and low spots, raked, watered, seeded, raked again, watered again and I'm stuffed...
Some parts are Like 75mm deep of soil Urgh....
Good work Jarrad :)
Quiet day today after epic night last night! Ocsober starts tomorrow :D gunna be awesome!
Rear main is in, Farkin PITA puller can't get the spigot bush out and it's rooted so I have to do it :/ so much for having the car going.... Grr
Oh and Tom (I think it was) I may be heading down to Texi to help the guys out.. My car IF it's running will make the cruise but not compete...
weak.
or saving for nats?
I remember what happened last time.
last time we had to scab cable ties to fix bov ha
ohh btw hey guys been flat out at work n lazy as f**k so havnt really been on
whats new :D
Yeah and an epic job you did :woot:
Hey guys, im getting a set of rims want to know if you GTR boys know if 18x10.5j +12 was a good fit or if i should go +15 or +22
From memory -> +15 is best -> check the cosmetic section, theres a few threads on r34gtr fitment in there.
What rims?
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
