i spent 1000 on my tools at work and got given 1400 bucks worth from the government for being an apprentice, wtf do you need so many tools for??
yeah, the government grants came into effect when I was in my 3rd yr.
no tool grants.
no rta allowances.
I was one of the last who done it tough.
had no missus and didn't go out.
thought tools were a wiser investment than wasting in a car.
I was right, been through about 6-10 cars since, still have the tools.
and so many tools, to make life easier.
instead of doing things the hard way, the right tool can make a big difference.
ant dawg shreading shit up!!
everyone must get one of these!! so much fun!!
ive seen big guys on these things to if certain people are worried.
60 bucks from kmart but stock wheels are shit so i got green machine ones for another 30 bucks which should last longer.
Which Kmart?
If they is that cheap I'm getting me one ASAP
What sort of brakes do they have?
Oh and Senic drive Merewether or Yule road or Mermorial drive Bar Beach or King Edward Park for down hill skids
waratah had 5 on friday and i got 1 of them.
might have to wait till next week or just shop around for the better "green machine" tyres cause 2 kmarts didnt have them in so i got the last 2 from toys r us.
there could be other costs like the seat may break after time, but if you got a school seat and bolted that on itd be sweet, and if you want to get real good all the 80km/h guys get pumped up tyres and put pvc pipe over them and bearings and bigger axles etc, but i cant see anything being expensive to fix/dodgy up
oh and brakes is just the 2 pads on the rim like a bicycle, not heaps good, i just tightened mine though and its MUCH better.
but think about it, its only metal and bicycle parts, everything is cheap and easy
haha and right on queue, was out the front of mine on the thin foot path for a bit more of a slope, drifted round a corner and didnt go round hard enough, hit the raised grass and it tried to throw me out, heard a slight crack,
seat has a small crack in it now which will probably get bigger haha, anyone good with fibre glass? thinking of just reinforcing this one cause its pretty comfy.
and mounting it a bit better.
may have to start a build thread hahahahahahahhaha
J-Rad I think I still got some fibreglass stuff here in the shed if you want that
The other thing you can do is go to Withworths or Bias and get a fibreglass repair kit, just make sure you get some 400gsm matting as the 200gsm is crap and a waste of time. As for making it stronger some plywood or always works well but fibreglassing is piss easy just have to mix the resin and catalyst in the correct ratio
thinking of getting a school seat now, just cause the stock seat is flimsy. though school seat will look cheap haha.
I will be disapointed if u dont get a bucket seat of some sort and mount it to it, just saying.
Hahaha yeah monthly pays would suck balls
Fortnightly I could live with
And yes a little short this week but not from holidays which rocked but the new company that does the pays at the hospital have f**ked up Melisas pay yet again and not paid her for 32 hours from the last fortnight
And don't even start me on the sick leave and annual leave fiasco the hospital has created.
its not that bad, i get fortnightly pay n sorta cope :P
also finally my coilovers are in australia, in customs now should be here this week :D
Nice one, my car is booked in for Saturday to get my coilovers fitted... Anyone keen for a cruise sat Arvo ha
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
