Hey guys,my sparkies need changing,
can any one tell me a shop who won't charge an arm an a leg to do it.
Oh some where fairly close to fingal bay woul be good. :action-smiley-069:
I should be able to help you with them and am only in Raymond Terrace.... We are all flat out trying to get ready for the cruise but should be able I help you out one night.... Send me a PM and we will sort it out :)
Went into bowers suspension to get some prices on coilovers and the told me they were fitting some bc's onto a yellow 34 gtr which im guessing is you.
Let me know how they go for you, im looking at getting the same ones fitted. Did they fit any other suspension components like bushing etc?.
Yea mate that was me...
Really happy with them, and the service was excellent.. Price was fair I thought also.
Have seen you around a few times, love the pearl white!
I could take you for a run in mine sometime if your keen, and could check it out if your coming to the cruise on Sunday?
Ant nice result with the suspension
Wedge. Any other day I'd be able to give you a hand but am putting a garden shed together for Dad then taking Melisa out
And don't think I've seen the white GTR around but The more 34's the better for the cruise
+1^^^^^^^^^
Or next Saturday I'll be there doing brakes so can help with plugs as well
Cheers, I'm not to keen on night driving,wild life an unfamiliar area.
Could you pm me a time and addy please,and i'll see you boys with a case of your fav tipple.
Genelle. :cheers:
Chookie, don't go to low or handling will be negatively affected by things such as bump steer and so on.
Ideally, you want your control arms to remain a bit above the parallel point, and you dont want to go below the parallel point.
When my S13 was lowered my control arms were still sitting a pooftenth above parallel....it got dropped 38mm in the front and 28mm in the rear.
looks great ant but why is there a big yellow car infront of it, you werent pointing at the car very well :)
btw, fitting my oil cooler and the bastard doesnt fit, the sandwich plate is missing something so hopefully i can source something by the weekend!!!
ok i need the gold threaded thing (i thought that was a nipple but it may be called a gland? idk.), it screws onto the thread your filter screws on and then filter then screws on it, like an extension. female to male
i should be able to steal something from work but there all for air, just wondering if itd make a difference? they look the same.
anyone know anywhere that would have that kinda thing? is there an... engine place around here? lol
im gunna try super cheap and autobarn etc but not sure how thatll go.
http://justjap.com/store/product.php?productid=20519&cat=317&page=1
Looks like Newy has had a killer weekend for mechanics, awesome work guys :D
My clutch and gearbox are in, it's faaaaarken amazing, still have a few issues to sort with the car....
Coilovers are an inch lower now the BCs are fitted :) painted a few things and did some general maintenance.... Also fitted the race car :D
Will update the build thread tomorrow
Any, car looks mint! Awesome! Pics have a nice effect to them :D
Genelle, just MSG on of us and we can sort out the car for you, if you want to bring it to my place on Saturday Martin and some of the guys will be here too :) its a pre-cruise working bee hehe
My number is 0434353292 if you want the address ;)
Cheers mate,
Glad your getting your car sorted, I still need you to take me for a run init!
As soon as its sorted properly I'll be happy too mate ;)
MSG sent cheers mat. :banana:
If you have no luck at work go to the place in Albert st Wickham can't remember the name now but used to be called Pitcrew and has all that sort of stuff
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
