can anyone with a 34 GTR please confirm for me if the following plug should be plugged into anything, my mechanic seems to think the 02 sensors are fine, he thinks the cause is the oil in the intake pipe getting on the AFM causing it to not read properly and to fix this i need to change the turbos out............... im not to sure what to make of that tbh
Is the car missing or is it just a boost problem?
if its AFM it should be running like shit and missing here and there i would have thought?
if its just not boosting sounds like a leak someone? maybe in the inlet manifold or something if its still registering boost?...
im not mechanic, just thoughts..
also if alot of oil is around the AFM.. could mean new turbos.. leak on the inside somewhere?...
If your talking about the plug near the twin turbo pipes yes it should be plugged in. Its either one of your AFM plugs or o2 sensors plugs.
If one of Your AFMS isn't plugged in, then this would explain your preiodic boost.
A little bit of oil residue in your pipes is normal - any running/pooling oil isn't and is a sign your turbos seals are shagged.
AFM's do funny things - particualry if there on the way out (i.e. speratic voltage reading). Down low they aren't really doing much, up high on the other hand....
Edited by wedge_r34gtr
Mine did a funny thing............................................................................................................................................. It went in the bin and i laughed! :laugh:
yea my car runs much better without them too.. but i did still leave them attached to the engine!
LMFAO THIS GUY BAHAHAHAH
Yeh i was like dafuq is this plug for?????? the oil is all the way to the airbox, my mechanic changed the plugs cleaned the AFM and it boosted and ripped then like 40km later it stopped boosting again, it misses as it hits boost and boost does not come on but the MFD is reading boost to .9 bar :woot: so its all spooling and shiz. i have 2 plugs that are taped togeather behind the twin turbo pipe and 1 is plugged in and 1 is not.
Well mine is suposed to be a farking specialist who has worked on these many times....... Team K Kustoms did the work the motor runs realy well the build is great on it even without it boosting properly it still has shit loads of power, im waiting on a call back from him atm, my main issue is the 20L of fuel it used to do 75km on the way to work.....
i might try unplugging the AFM and see if it runs without them and comes on boost, after he cleaned them and changed the plugs yesterday it went like a rocket, he thinks the turbos may be spitting oil back up the intake pipes and coating them in shit so they are not reading correctly.
Edited by T4NK
yea see what your guy says...
i cant imagine it would run too well unplugging the AFMs...
Does it have an aftermaket ecu? was it tunned after the build? sounds like it is running very rich....
stock ecu, not sure how much u can tune a stock ecu.... well if it will come on boost with the AFM off then i know thats the issue and i just have to work out why all this oil is in the pipes
yea cant tune stock 34r ecus.. mine had a custom chip installed onit that was very rare that could be tuned, but there arent really any people who tune it anymore so its pretty useless.. ive got a haltech running via MAP now.. much better!
yea a large amount of oil sounds bad.. maybe check pipes on the other side to see if there is more up near the inlet etc?..
The soldering joins on my Afm f**ked up when I cleaned it. Can't remember what happened though... Not it either wouldn't start or revs were bouncing all over I can't remember. But as Joel said it could do funny things when on boost because more air more volts and boom.
I would only be touching what your mechanic says dude. If you f**k something it's bye bye warranty.
ATM it's his job to fix it not yours
Yeh he told me to give the pipes a clean and the AFM to with the spray can cleaner, at lucn im going to get some paper towels and open the pipe and give it a wipe down around the AFM i dont have the tools to get to the one under the airbox, might have to park the car up at home and get the train for the rest of the week.
Proven 6% better flow when you gut them. DONT GUT WORKING MAF's THOUGH!!!!
This pic lets you see the plug better btw.
Follow the lead - where does it go? it's definatly o2 or MAF though and the other end should be around that location somewhere.
Did someone say dash 7s??
Just keep modifying until it's fixed IMO :)
This man nailed it
If in doubt MOAR boost! :woot:
The answer to everthing in life. More boost.
If in doubt - 30+psi and RWD is the answer.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
