Enjoying the sound of an SR is an aquired taste....
Just to recap on the last comment, assuming your understand this is Skylines Australia..... And skylines have RB's which are awesome....
Your SR has as much value as the tampon Pulled from a fat chick in her P
i know wat ur sayn mate and i agree in a sense until a couple of weeks ago when i was at jezas shop and he had a built sr20 in a s13 with a precision turbo make 335kw on 24psi (low boost) :woot: the thing was a animal the owner was lookn to run 37psi high boost.it sounded awesome :yes:
Hey benji,
Has extreme super ultra late braking as per your driving style ever sent you off into a field?
I mean come on how late can you brake with metal on metal brakes??
haha read that this morning and was thinking the same thing....
should add 'to infinity + 1' after it just to be sure :)
Hey benji,
LOL
I havent driven the car since I took it for a drive when I got my full licence (based on advice from everyone).
My driving style always is extreme ultra super late braking.
Front brakes are fine, rear brakes are metal on metal. When I had my drive after I got my full licence I just relied on engine braking by downshifting early... and then quickly pressing the brakes firmly to pull up to a stop.
Wakefield RaceTrack
When I had my trackday on July 25th, The rear brakes became metal on metal in my last session, and naturally I just thought optimistically and assumed I was getting pretty severe brake fade and that my pads were just on the replace indicator (little metal shavings to warn you that your pads need to be replaced).
The rear end felt very unstable and very twitchy as the metal on metal brakes at the rear weren't grabbing evenly, and I really had to manhandle the car to keep it on the track. Goes to show how good the front brakes for the S15 are, considering I was still cannonballing down the straight at about 160-170kmh.
Hey benji,
Link please
Oh and the L/H at work can go f**k himself
Took three hours work off Fridays run cause he thinks I will run out of hours.
Seriously I could do it in 10 hours tops with my eyes shut
Really over the shit at the moment
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
    • Hey all, Noticed I have a hole on top of which im guessing is my transfer case/gearbox. I can see it from the middle of my firewall looking down. S1 R33 gtr Any advice or can pinpoint what this is/caused this?
    • Looks like you were right on the T pattern! I did that and it's finally fixed! Thanks a bunch.
