Yea sorry Martin were abit late, we were on the road by 1030...
Roads were very rough, therefore very slow! There was one good section from dungog over to buckets way, but apart from that, wooten was great! Smooth and very wide, and 100kph speed limit and no other cars on the road.
Will hit it up for the next run.
That's alright
Dungog to Buckets way is called Stroud Hill Rd. hope you had a run up the hill while you where there. I can tell you that it is easy to overheat the brakes in a truck heading down those turns.
Wotten way sounds good with lunch at Foster and back the lakes way?
For once Benji might be onto something here.
First very usefull post I've seen ever from you
Price on some 550cc or higher injectors for a 25NEO please
If you want cheap big injectors look up the thread from Simon-S14 about them....
I run XSPURT 1000cc which are originally bosch then modified...
You need ECU and tune etc for bigger injectors so work out what ya wanna do and do it all at once
Oh and gtts don't break.
Well... mats does haha
Put your money where your mouth is sweety, 3rd and 4th gear powerskids all day at the track and apart from the ECU going into a safe mode for a sec it was pure mental fun!!!
Plus I break anything I touch.... Passion fingers?
New turbos, moar boost, ecu in feb next year with injectors then ill slay every HSV i find
yeah, but that kit doesn't come with the adjustable acutators to support higher boost. The -7's & -5's kit's do. The actuators are about $200 from memory. Still a nice price though
Edited by wedge_r34gtr
f**king skids was good fun hey mat :D
Fark yeah.... Dave has some good vids.... I held the limiter in 3rd too the barriers on that back straight, struggled to pull it up for the corner lol
And you getting kicked off for Dori skids just made it better!! R34 Newcastle represent!! No farks were given about the rules lol
hmm a m8 of mine is telling me to get -9s for street gtr -5s for track/drag
Most circuit, rally and drag cars actually run bigger turbos as they spend a good part of their life on full throttle and boost, unlike the start/stop on the street etc :)
Yeh looks like im gona go with the -9s brand new i think, im still looking at a 2nd hand set of -7s atm but its going on dadpos so may as well get the -9s now and do it right the 1st time, i have droped the power im looking for from 400kw down to 350kw and i think ill struggle to get near that with the -7s. the -9s should get me close to it. Im going to use the standard actuators on them for now, apparently i can put the actuators i have on them now on and they will run the stock 1 bar no issues. I wount be able to do much more for like 6 months as ill have to pay my dad back for them :rolleyes:.
Went to see DVS Jez today, he pulled all the intake pipes off, front turbo has a bit of play and not much oiil in it, rear turbo... well there was a pool of it in the pipe thats direclty off it. The weird thing is im not getting any smoke out the back, im going to have to have all my pipes degreased and the cooler also when the turbos get changed and the AFM cleaned/replaced.
Im looking at getting them from Kudos or boostin imports waiting on quotes, ill also get Team K to get me a price through his connections for a set also see how she goes, with any luck ill be running 1 bar boost next week on a set or -9 going into warp speed.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
