Yea sorry Martin were abit late, we were on the road by 1030...
Roads were very rough, therefore very slow! There was one good section from dungog over to buckets way, but apart from that, wooten was great! Smooth and very wide, and 100kph speed limit and no other cars on the road.
Will hit it up for the next run.
That's alright
Dungog to Buckets way is called Stroud Hill Rd. hope you had a run up the hill while you where there. I can tell you that it is easy to overheat the brakes in a truck heading down those turns.
Wotten way sounds good with lunch at Foster and back the lakes way?
For once Benji might be onto something here.
First very usefull post I've seen ever from you
Price on some 550cc or higher injectors for a 25NEO please
If you want cheap big injectors look up the thread from Simon-S14 about them....
I run XSPURT 1000cc which are originally bosch then modified...
You need ECU and tune etc for bigger injectors so work out what ya wanna do and do it all at once
Oh and gtts don't break.
Well... mats does haha
Put your money where your mouth is sweety, 3rd and 4th gear powerskids all day at the track and apart from the ECU going into a safe mode for a sec it was pure mental fun!!!
Plus I break anything I touch.... Passion fingers?
New turbos, moar boost, ecu in feb next year with injectors then ill slay every HSV i find
yeah, but that kit doesn't come with the adjustable acutators to support higher boost. The -7's & -5's kit's do. The actuators are about $200 from memory. Still a nice price though
Edited by wedge_r34gtr
f**king skids was good fun hey mat :D
Fark yeah.... Dave has some good vids.... I held the limiter in 3rd too the barriers on that back straight, struggled to pull it up for the corner lol
And you getting kicked off for Dori skids just made it better!! R34 Newcastle represent!! No farks were given about the rules lol
hmm a m8 of mine is telling me to get -9s for street gtr -5s for track/drag
Most circuit, rally and drag cars actually run bigger turbos as they spend a good part of their life on full throttle and boost, unlike the start/stop on the street etc :)
Yeh looks like im gona go with the -9s brand new i think, im still looking at a 2nd hand set of -7s atm but its going on dadpos so may as well get the -9s now and do it right the 1st time, i have droped the power im looking for from 400kw down to 350kw and i think ill struggle to get near that with the -7s. the -9s should get me close to it. Im going to use the standard actuators on them for now, apparently i can put the actuators i have on them now on and they will run the stock 1 bar no issues. I wount be able to do much more for like 6 months as ill have to pay my dad back for them :rolleyes:.
Went to see DVS Jez today, he pulled all the intake pipes off, front turbo has a bit of play and not much oiil in it, rear turbo... well there was a pool of it in the pipe thats direclty off it. The weird thing is im not getting any smoke out the back, im going to have to have all my pipes degreased and the cooler also when the turbos get changed and the AFM cleaned/replaced.
Im looking at getting them from Kudos or boostin imports waiting on quotes, ill also get Team K to get me a price through his connections for a set also see how she goes, with any luck ill be running 1 bar boost next week on a set or -9 going into warp speed.
    • I had a 1981 ALFA with an electronic speedo sender that would work for months at a time, and also noth work for months at a time.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
