Thanks man, appreciate it!!!!
Benji real cars fit Pads and Rotors..... Wtf is a hardware kit? Are you fitting a bench vice to your control arm?
The shims and clips things are the hardware kit...
Heres a hardware kit for S13.
Once funds permit, I'm going to be ordering a vented carbon fibre bonnet from japan
Not really in a hurry for rims as Ive got a pretty much fresh set of KU36's on that set of rims atm.
And coilovers etc are going in in January. From where its at, only needs to be lowered 10mm in the rear and then the control arms will be parallel all round. So I dont negatively affect handling, I'd need to spend more money on things like roll center adjustors if I decided to go any lower than that.
yep - welcome to the joys of gtr ownership.
nice price on the 9's - thats basically what i paid for my -5's (which are usually a few hundred cheaper)
Edited by wedge_r34gtr
Come over to WA and keep me company :-)
What is the work situation like over there?
Could realllly consider it in the new year.
As for car stuff I saw Paul today and got the motor back on track. Also picked up a nice shiny catch can/washer bottle
Mjh, I washed my car today and just polished it afterwards....
do you have any tips on detailing?
Best thing you can get for detailing is a Concours 900 RO kit.
Car looks good as is just get a good sealer and wax to help protect the finish. Check the detailing thread and also check out the Waxit site for quality waxes etc
Work's pretty plentifuly, lowest unemployment rate in the country.
i know that catch can, its really shinny :-)
Did you get a water pump? Paul kept hold of my spare N1....
Yeah just went with a VL pump.
N1 pumps are more for higher revving motors aren't they? EG drags tracks etc
I'm giving some serious thought to a different job.
The one I have now is good but not enough work or pay
Some guys manage to do 12 hour days regardless of how busy or quite it is an I seem to get the easy short run most days
http://www.gumtree.com.au/s-ad/hoxton-park/cars/nissan-skyline-gtr-must-see-goin-cheap-1995-model/1009072657
14k maybe less could be mine this weekend.
thoughts, fears, loan??? haha
I could very well be wrong but don't GTR's have a BNR prefix for the chassis number?
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
