I could be wrong, but I'm pretty sure it's the other way round mate.
Who's telling you this? The seller?
-9s are An updated version of the -7s, pretty much the same response as the -7s but flow a fair amount more. -9s on the same set up make more than the -7s etc...
i spoke with DVS Jez, and a few other ppl they will make the same power diff is, the -7s have more top end and the -9s have a bit more down low, but in the end they will both do the same job.
also ill be getting a platnum pro plugin for her.
Edited by T4NK
yea fair enough, i really thought it was the other way round though. -9s being slightly bigger but better in design, therefore only a tiny bit more lag than the -7s but more top end..
i was fairly certain the -7s were the smallest upgrade turbos you could buy, but there is so much confusion around these turbos that i wouldnt be suprised if i had it wrong haha..
Wedge you know abit about this dont you?
The only difference between them that i can find was the exhaust wheel 1 was like 3mm bigger then the other or somehting like that. But i cant wait 3 weeks for -9s anyway so -7s will have to do im over all teh waiting and f**king around, just want it to run so i can enjoy the car.
yea fair enough mate.
just be easy on the clutch when you get it back, its generally the weakest part of the car from stock. and it is advisted when going with bigger turbos to upgrade it etc..
you doing anything else bar turbos and computer?
I'm not 100% sure but i believe the exhaust housing is slightly different design on the -9 too.
-7's = r34 n1 turbos
-9's ARE HKS GTSS turbos
The graphs i looked at when researching turbos showed <150rpm difference between the two (-9's been slightly worse), but the -9's usually had the better top end (10-15kw's), however this is highly dependent on supporting mods and i couldn't find any back to back comparisons (who's going to waste 2.5k to go from 7's to 9's unless the've blown a turbo)
TBH throw 20-24psi through either of them and your going to be making ~330awkw and absolutly exstatic. You can't really be disappointed with that.
Edited by wedge_r34gtr
Good stuff - that means all three of us a runing platniums.
all this talk of turbos is making me very keen for the next stage on mine..
seriously going to have to consider E85 i think.. have seen results with a similar planned setup as mine making 370awkw!
will be hard to pass that potential up i think..
Yep - I've been saying for a while i rekon it would be possible to crack 400awkw with E85 with 9's.
Someones 34nur in melburne made 379awkw with 7's (stock n1's) and E85 recently.
Yea I reckon 400 would be too much for those turbos... Could probably get a dyno to read it, but how accurate?...
I'm pretty sure both run out of puff around 22-24psi?...which would restrict huge top end power etc...
Yep, going to do mid pipe on my exhaust since the cat back is 3 and a half inch and so are the dumps but has the stock mid pipe, also needs a new clutch as mine is almost shagged, will do injectors and maybe fuel pump with the ECU, then after i have it all sorted in a year or so i may put a big single on it when i get another car as a daily, and go for massive power since the engine is built for it.
ohh and i hope everyone has taken the restrictor out of the side of the stock air box to, it just pops out 2 clips just use a flat head screwdriver, will double the air into the box, i can now hear my car sucking in that sweet sweet air as i thunder down the roads lol.
Edited by T4NK
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
