atm our fb page group is called sugarloaf speed stars. it keeps getting changed cause the admin (paul) thinks he is funny. at one point the page was called 'daniel's r33 is better than we expected but he should have bought a mx-5' we are having a meet this thursday night. if anyone is interested ill fill you in with the details.
Link????
I think the multi layer would handle the pressure and heat of a turbo better than a std exh gasket
But whatever type was on there before should be what goes back on I reckon
Just my opinion anyway
Oh and spot to a red 1600 coming from the crossroads to Cardiff this morning
Yes that is my brothers 1600, i'm trying to convince him to come on the cruise on the weekend, there was a nut missing as well which i put another one on which made it quieter but its the gasket as well so i will be doing it Saturday ready for Sunday :) if its not ready ill bring the datto
Ill be back in here whoring up the joint soon enough guys! Still striuggling to keep up with work and got heaps of stuff to get done!
Going to be an epic cruise on Sunday, sort of sucks i wont be there but i was told by car wont be ready anyway so its no biggie!
To keep Chookie and Kurtis happy we are now going to the 3 pump setup and external etc etc but i am still waiting on the details!
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
    • Got my 34 gtt tuned last week. Car made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now.  IMG_7261.mov
    • Hi everyone, I'm wondering if anyone in Melbourne (preferably West) has a non-S2 R34 front bar. If it's already off the car, even better!  Nothing too weird, I just need to get a cut-out of the hole that the front indicators clip into 🤣 (image attached for reference)   I've got a front bar from JSAI Aero, but those holes need to be cut myself, and I want to get it right so the indicators will clip securely. And my OEM bumper is a S2, so I have no reference. So looking for a member who might be able to spare me a few minutes to make a cardboard cut-out using your front bar.
