atm our fb page group is called sugarloaf speed stars. it keeps getting changed cause the admin (paul) thinks he is funny. at one point the page was called 'daniel's r33 is better than we expected but he should have bought a mx-5' we are having a meet this thursday night. if anyone is interested ill fill you in with the details.
Link????
I think the multi layer would handle the pressure and heat of a turbo better than a std exh gasket
But whatever type was on there before should be what goes back on I reckon
Just my opinion anyway
Oh and spot to a red 1600 coming from the crossroads to Cardiff this morning
Yes that is my brothers 1600, i'm trying to convince him to come on the cruise on the weekend, there was a nut missing as well which i put another one on which made it quieter but its the gasket as well so i will be doing it Saturday ready for Sunday :) if its not ready ill bring the datto
Ill be back in here whoring up the joint soon enough guys! Still striuggling to keep up with work and got heaps of stuff to get done!
Going to be an epic cruise on Sunday, sort of sucks i wont be there but i was told by car wont be ready anyway so its no biggie!
To keep Chookie and Kurtis happy we are now going to the 3 pump setup and external etc etc but i am still waiting on the details!
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
