http://www.skylinesaustralia.com/forums/topic/414822-r33-gtr-series-2/
god damn i want this!!
mad price!
Rb28, -5 turbos (probs change that), seems like a heaps genuine seller, saying it has a couple dings but there getting fixed before sold.
also, found out today im not being kept on for my apprenticeship but i may get a job for the same company but maintaining the locos that ive built for the past year, better hourly rate, and rolling roster between day and arvo shift with 4 10 hour days with the option to work any friday. a bit keen...
yeah ill find out hopefully this week or early next if i get the job as the email and everything has been sent.
dont think im gunna worry about the mines, the casual blokes at my work are on 40 bucks an hour and thats standard for newy, when you think about the distance and then having to rent somewhere in singleton ill either be living rough or saving less money then working in newy and coming home to emma every night.
plus i doubt id get in a mine cause i dont have family in there :S
http://www.skylinesa...3-gtr-series-2/
mad price!
Saw that. good price....but way down on power for -5's...but it wasn't exactly seeing much boost. Also, don't know where you got the rb28 info from.
.8 sump with baffles??
that not 2.8??
yeah i thought that about boost, would expect 280 atleast
nope just an extended sump. Mine's still a 26 and holds 9L (11L if there's oil in the cooler)
rb26's can suffer from oil starvation. With a combination big G corners, high rpm's and a poor head oil drainage design, the result is that the stock pump can essential empty the sump and thus suck air = no oil for bearings = spun bearing. After market pumps can flow more then 25% higher then stock, so the problem is amplified. The larger sump capacity pretty much eliminates the lack of oil problem and the baffels keep the oil around the pick-up during high-g corners. n1 engines came stock with a higher oil capacity, so nissan was probarly aware of the problem from there racing experince.
ahh i see, fair enough then :P
whats the advantage of a bigger sump??
hey joel hows WA? good to see your still lurking newy :D:D:D
i still check in from time to time :yes: . I'm bored at work and the WA section is dead.
WA's going well. Still haven't found a house yet though...and I'm really missing my tools (their in storage). Hopefully i'll have one by the end of the year and can start to settle in then.
ah right, where are you now then??
id imagine everything to be expensive as!
Work's got me a place in the middle of the city for a few months - it was part of a relocation package. Trouble is, i'm still working up in Port hedland, so i'm never actually in perth to be able to look for houses.
Yeah it's probably about 20%-30% more then newcastle for just about everything. But good city, very social.
I went 4wd on the weekend with a few mates, the old ferroza held up well conwsidering it's completely stock:
wow crazy!!!
newcastle is expensive enough!! cant beleive people buy investment properties in the illawarra compared to a lot of other places in the country!
jesus dude!!!
didnt know the old girl had that in her!!
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
