So Martin where is this track? Can I bring big bird for a run onit? Ha
Aw man if I saw this post in time yeah you could have run.
Had a good and bad day with the car though
Was getting used to driving it then played with tyre pressures and got that sorted then dad had a drive and I jumped in straight after and was having a real go at it when I noticed smoke from under the bonnet then lots of lames from oil fire
Stupid bonnet clips meant we took about 30 seconds not 5 to get bonnet undone and put fire out
Burnt some wiring and coil lead and overflow bottle as well as the bonnet itself.
All because of the stupid plastic line for the oil pressure gauge which got hot and melted spraying oil everywhere
Still can all be fixed, at least it happened on a Test day and not the first event.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
