yea the only problem is i need to take out the whole stem, which will require the wheel and tyre to come off. bit of a pain in the ass! so might not get around to doing that for a while unfortunately.
the yellows go together really well.
ah to easy mate, will catch up in the new year sometime.
yea i dont know, will turn out pretty shit i think, or i will get paint on my wheels etc..
see what happens, i may be able to get ones soon then get them fitted when the sway bars go on.
How'd you go with the swaybars man?
haha, thanks but no thanks jarrad! have done all this effort for the wheels, not going to finish it off with dogey painted valves, which i would have to take off the wheel anyways to do a decent job ha.
was very nervous putting the stickers on yesterday, nearly stuffed the first one up. in the end did a pretty good job i think. would be much easier with the wheels off to do that aswell.
good mate, they are sitting in at bowers, my car is booked to get them fitted there first week in jan. very keen!
A
Awesome! You will be happy with the way she handles after that!!!
yea we will go for a run somewhere!
will pass around details closer to the date, but looking at the forth of jan at this stage.
Hmmmm MAY be around for that! Is this going to be a hush hush cruise? :woot:
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
