...waits for informal cruise to be cancelled.
lol just kiddin Benji
Hows the S15 going?
Apparently the brakes dont work :P
Now you just need some NOS....two of the big ones
And Harry, i need em by tonight!
That's not good :wacko:
it's been like a 1000 posts since the last F&F quote...it had to be done :woot:
Good work! Can never have enough F&F quotes!
Did you see the new updates man? You updated yours lately??
ok its on at details are 123 fake street starting at 2500 hours...
hahaha
jokes, all good, all welcome
hahahaha nice one Ant, its a long drive though -
http://www.zillow.com/homedetails/123-Fake-Street-Long-Beach-CA-90802/2120044872_zpid/
yeah...saw your dodgy balancer...lucky you saw it before your crank nose wore out.
No major updates for me. Car's got a massive oil leak from one of the new braided lines and i haven't had time to sort it. Parts wise, i'm hoping to pick up my front pipes, rocker covers and cat from Paul while i'm over east and get them installed while i fix the leak. Then it's going back to the tuners for more BOOOOOOOOST!!!!!!
Nice! When you back again? I think you said it but i forgotz
Hows the S15 going?
LOL, S15 is going well....noticed a couple of pindrops of black oil on the piece of cardboard (which is under engine bay where I park) but meh, I dont know where its coming from so probably nothing to worry about.
Steering feels a little vague but that comes down to the fact it still has the stock suspension setup (with the struts leaking)...
The car definately has a lot of potential though and is an awesome platform.
Also re: brake situation. I left my car outside a mates house in Sydney parked on a downhill slope with my steering wheel pointing slightly to the left (luckily) and I pulled up the handbrake and left the car in neutral (should have put it in reverse). Anyway came out later, and the s15 had probably rolled down the hill about 3-4 metres before mounting a driveway/gutter. Luckily no damage underneath though due to tractor ride height :D
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
