by the way guys, anyone who hasnt had a cams license before can go to the cams come and try day, 30 bucks for 45 mins on eastern creek, im so jelly i cant enter
When is this man????????????????????? I only have a AASA so may be OK?
looking good mat! you picking it up soon?
Yeah just trying to work out a time that suits both me and JEM! Hopefully real soon as i need to get it past rego!
IS THE RINGWOOD COME AND TRY DAY ON THE 19TH OR THE 20TH?
20th i am pretty sure mate! Ill be there!
Just to clear up any confusion
The 20th is a hillclimb event at ringwood and is the first for the year. I will be there in the new car but am also going up on the 19th for a practice day to bed the new tyres in
There is a come and try day at Ringwood on the Sat the 16th of Feb for those that want to attend
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
