every time i fix something, something else breaks. every time i take it to the mechanic they find another 50 problems. however i havent really gotten my way with the car yet.
Haha maybe your car and mine were friends back in J land, sounds like the way mine was...... BUT its more because i modified the kent outta mine and kept breaking stock bits lol
yep...you made it sooooooGATTTTTEEEEEooooooo much better....but ruined it at the same time :-)
Had a go at formula fords today.
Think im going to get into karts, going to try organise a try day at cameron park, let me know if anyone would be interested in coming along
Interested...
150 for 3x10 lap sesions, last one is timed and ranked.
Need 10ppl and is through the week...
Not a bad deal.... I'll be stuck at work for the next couple of months tho... So not likely to be able too :/
would like to try formula Ford's.
How much for those?
and I doubt I'd fit in the cockpit.
How much for those?
its through those 'adrenalin' deals online. $350 gets you 10 laps around a small section of eastern creek (takes ~ less then 1min to complete a lap). because someone cancelled in our group we got 15 laps each, i would reccomend 20laps, as you do that in two parts.
its not the best thing ever, but is alot of fun. they are proper formula fords, but they put used wet tyres on?... and they may be detuned slightly?... but still went pretty hard and cornered well.
i think you would be fine fitting in. they have limits of like 120kg and 200cm or something like that.
sounds like a good day ant!
Paul has a go kart he takes to Cameron park.
looks alright but wakie is cheaper all day in something much faster ;)
really, i might need to hit him up... im heaps keen to give them a go.
i wouldnt say wakie is cheaper?... (i dont know the full costs of go karts yet though) but wear and tear on cars, even setting them up for track is very expensive. and karting you can actually enter races and be competitive as far as i understand, instead of just beating your own times etc..
not to say if i do get into karting i will never take the gtr on the track, there just two different things..
im guessing you could race all year in a go kart for maybe 5k or under including buying a kart?..
Alex races a kart too. loves it! He has the Evo but is converting that back from Time Attack spec back to a streetable nugget and just using the kart for fun as its so cheap!
Wakie isnt cheaper when you factor fuel, accomodation and track time, last time i went there it cost me $6500 :P lolz
yea i think thats what im going to do hey.. sounds really fun.
and how else can you have proper races for such a low price..
very keen!
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
