whos organising the next cruise and where to? its either martin or chookies turn to organise, unless someone else would like to have a turn and choose a route theyd like to show everyone?
Good question
Might have to decide over some drinks when everyone can be there
u may have to stay home for the next cruise if u sell ur car mate.is anyone from newy goin to the top secret car meet at eastern creek on friday night?
Ill be driving to Bathurst, not sure what time as it depends on when I finish work
If you happen to see an old Hiace van towing a white car trailer give us a wave otherwise ill wave from the M4 as we drive past
Yeah sounds good
Could do with the extra help to clean tyres check temps pressures etc after each run
Meet at the circuit 630 Sat morning
i'm already here lol.
why are you going down?
F*ck'd if i know
It's showing up on eveyones now.
Yeah and some kent left 2 Neutral feedback today :whistling: Asshole!
I'm heading to newe tonight. Going to claro around 7pm for some beers and triva and if anyones bored
Having beers and dinner at Raymo with mates if your cruising past!
Bastards!!!
Coming from orange via Sydney, See i'll see how i go :-)
Edited by wedge_r34gtr
Bastards!!!
The leather jacket skinny jean wearing, bread hammer throwing kent!
    • If your head gasket lifted, you should have seen a coolant pressure spike. There's no need for a copper gasket/fire rings at 30psi. An MLS with perfectly clean/flat mating surfaces should suffice.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
