On that note, where the fark is Chookie? :blink:
still breathing
fucing 2 jobs is the worst for any time to play with cars or myself ;)
also jarrad when can i come buy my car bits off you :)
thinking i need them parts for a goo fast run up sugy again :D
still breathing
You hoon! :P
today? tomorrow? now? you white boys work fast, eh?
you still working at officeworks?
LOL i even had the correct voice while reading that!!!
I need to take my car for a drive sometime tomorrow... been a fortnight!
I know that feeling!
Hi guys anyone upgraded there diff in there 34 if so how much and what did you do?
Yes, $600 for second hand Nismo centre, $350 to rebuild and reset as 1.5 way!
There is a guy that had one on Ebay for $300 with $50 postage but it was Kaaz 2 way, a little louder than most but work pretty damn well!
who doing the next cruise? people from work keep asking me what's going on
I'd say putty was a success :P
chookie or Martin?? suggest some dates and routes??
If you leave it to Chookie he will end up Routing Dates :P
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
