2nd weekend in June is the long weekend as i am booked to have a crack at the SAU NSW Texi day!
Was talking to Martin on the weekend and a cruise will definately go ahead! June will suit me as this month is flat out!
We should start planning early and set a firm date so that way we have it locked in!
I still think Wootton way is the go for the next one, you kents decide the route as we discussed at the KENT :P
yea to easy, you organising it then martin?
i think the best option is just up to wootten way and back, lakes way is abit dodgey and we dont want chookie to bust another rim or tyre ha..
Good point re the rims and tyres
Ill have to check race calendar but will set a firm date for whatever weekend is free in June
Up Wotten way to the end grab some roadhouse food and back again how's that sound
Cruise sounds good. Dont think ive been thru wooton way yet. Does anyone have a 32 gtr y pipe, cat and exhaust i could borrow to pass epa inspection? For some reason my car is a little bit to loud for the po po.
Sooks! Haha, check with DVS JEZ? He may have the stocker laying around?
sounds good, not sure where the best food is? in buladelah? i dont know what is further north?
Martin seems to know where the food is :P Ask him hehe
Not much further north is Coolonglook with s roadhouse then Nabiac then Foster
Probably just turn around for a pub lunch at Buladealah if no one wants to go any further north
Get details of the food place of choice so we can lock it into the details man ;) if you want, when you come round this week we can discuss it and ill sort the cruise out ;)
by the end of wooten you wont wanna go any further. take ages to get there alll fwy until wooten way then a bit of fun.
Stahp talking about me kent! :P
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
