Haha its about time I get better wity working stuff anyways jarebare.
Bbq sounds good. Im also busy atm, get the keys for my house today. And the nats, again hard for me to get time and money as im now a home owner to!
Fkn home owners!!! Oh, we are looking at open houses tomorrow lolz
As for the BBQ we can pick a date with plenty of notice, can be fkn Bathurst weekend if it needs to be? I'll set the TV up on the deck with some lounges etc.... By then I might have a beer again, will be well over 3 mths by then :/
Im down for that... Been a while since I went to a Bathurst BBQ
Oh and was looking at the rear bodywork on the racecar the other day
Had a dark line about 2 inches wide right across the back and I thought I had f**ked up the paintwork somehow
Was actually dirt from the air pressure doing funky things at the back of the car
I see you tagged some of mine
As my car takes good pics why not
Could include go kart maybe???? Hahahahahahaha
Lol ill get some on there for you! No farken go kart!
Actually technically you arent an SAU NSW member but ill add it anyway cus i can :P
Where's my stickers kunt
So what's been happening
My cams finally got found so now have one week to assemble and tune car for next event
Lots of late nights ahead I think
  • 1 month later...
yea seems everyone is really busy these days... myself included.
someone else can step up and start organising things again maybe??
Ill be back on board once we move and the small place is sold mate! Once that happens i am happy to help out again, until then i gotta work hard to get it done :)
I still wanna get over and check out your new pad mate! Sorry we missed your do, we were sunburned and buggered from renos!
yea all good mate, sounds good...
hopefully i will still have my car... thoughts of selling have been cropping up again, but probably not untill the new year at this stage.
:( Noooooooooooooooooooooooo
Hopefully the track day and the revival of some cruises and car events will change your mind? Bring it to the hillclimb on the 2nd November too! Cheap fun and not too much stress on the car!
