Nah nothing's up man
Put go kart together
Hillclimb
New axle and springs in boat trailer so it will make the trip north at Xmas
Fit radio and whatever else I need to boat to make it sea worthy
Xmas parties
Track day for go kart at Wakefield
Fix axle seal in Melisa's car
Fix skyline and service
And want to try and get house painted as well
Just a few things to do
pretty quick!
benji theres a socket you can get that makes that a 2 minute job. a socket with a cut up it so the wire doesnt get tangled
yes used that socket but ABS booster is in the road and the heat shield for the manifold. Had to use a hole heap of extensions and joints lolz.
ended up having to take off my strut brace to screw new one in (I hand screwed it in as didn't want to risk cross-threading).
I will keep an eye on any beers (if its an open invite :) )
My car is off to Nathan @ Newcastle Dyno tomorrow for a tune and boost controller! Not expecting numbers much different than standard but hoping to get a mid range improvement.
Have you got adjustable cam gears? they beef up the midrange quite alot, they did for mine anyways.
Only mods are -7's, xforce dumps (I was told this is helpful when changing turbos), upgraded fuel pump and splitfire coilpacks (prob don't count as a mod).
It doesn't feel as responsive since the turbo changes and I am concerned about running these with standard ECU and boost control. The only reason I have made any changes was due to the possible failure of the ceramic turbos and everything else has kind of flowed on.
It is getting a PFC and Greddy profec-b tomorrow.
After this I plan on keeping it as stock as possible, well for a while at least :)
Edited boost control reference
Edited by djrobertshaw
haha yeah, probably should have explained that.............I know the standard boost solenoid does its job, but keen on running a low boost and hi boost with appropriate tune.
I may have been misled but a few people have said running -7's can see boost spikes with standard ECU and solenoid.............and its a neat excuse for the wife anyways!
The only things i would have added to that list is injectors and cam gears, the cam gears should improve response (only if its tuned properly aswell etc)... with the above you should be able to get 300+ kw at all 4 i would think...
your injectors (if there stok) will probably limit you to around 260ish and stop you from making best use out of the nice turbos you now have :)
hope that helps, although sounds like it may be a little bit late if its going in tomorrow.
Thanks for the advice.
I did consider making more changes but budget and trying to figure out what my plan is means that a couple of small changes now and then probably wait for the inevitable bang before doing more.
On a side note I am looking to change the color of the BBS LM rims, do you guys have an experience with anyone locally? I may just do it myself but if there is someone good then lazyness will prevail.
Nathan does great work
Rims are something you can do yourself but would be better left to the pros
Paint is one thing you get what you pay for and if the finish isn't spot on it will detract from the rest of the car
I can pay t but it is a 1-2 metre finish
That is it looks great till you get that close then you can see the minor blemishes
Is okay for racecar but not my car
Find the best painter you can afford wether it be a panel shop or bike repair/custom shop and get some quotes
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
