I'm not a fan of stretch at all (but that rim had bugger all ant). My rule of thumb for the minimum is 255 for 9.5, 265 for 10 and 275 for 10.5.
Not a bad rule...
Yea neither really.
I don't want to push going wider though due to rubbing...
Yea neither really.
Rubbings racing.....
Wow, days of thunder, must watch again... Was the fast and furious of its time :D
Yea neither really.
yeah true. From memory, i think you can get away with 285 on 10.5 without dramas. A 34gtr lowered due to coilovers may not.
I think you can run 285 30s on 18s without too many drama, but 19s would be pushing it I think.
I wanna run 285's :(
Oh, and on a positive note (not for me as I'll wanna kill kunce) I am signing up for Ocsober... And u kunce have to Put up with me for a month with no beer.... It's not pretty but I'll do my best!
Greetings from budgiwoi guys. :action-smiley-069:
Hey hey, how you doing? Next cruise is booked for the 21st of next month, will you be around?
Oh, and for all you guys that know Jez -
http://www.skylinesaustralia.com/forums/topic/409610-happy-birthday-dvs-jez/page__fromsearch__1
Thought it would be a nice idea :D
Hmm I might be out for nats boys.
People have been losing jobs left right and centre at work because we haven't got any contracts after dec and they said today all 4th years that can be signed off early will be in nov. I'm guessing all that can't may be told cya later. I'm not sure if I'll be able to or not yet but should be ok.
But I don't think I'll get a job till after Xmas as everyone is telling me people to hire till mid-late Jan.
Thinking after I spend 1k at nats if something blows or I come off and break shit and I don't have income it could result badly.
Still haven't made up my mind yet, idk. Would be fun but I don't wanna blow an engine or something the. Have 1000 bucks to last the summer haha
http://www.skylinesa...__fromsearch__1
Hey matt,if i'm up here then in for sure. genelle.
You wont break the engine but you do have pads, clutch, tyres etc that will cop wear!!!
Just come down with us anyway if you want mate? Dont want you to miss out on a good thing....
Awesome! Will be good to see you again.....
Unless you going to Texi? Then i may see you there as i will be off the drink so no point sitting around and watching Bathurst without beer, would be Un-Strayan!
hmm i think im mainly worried about the clutch, the trsut bearing always makes a grinding noise for a month after a track day.
idk, it should be fine.
i got some uplifting news today after writing that post so i may still enter.
just gotta hope people will be hiring in november i guess or ill be applying for supercheap over summer hahaha
My clutch went all of a sudden so i dunno if yours has been done or not, but it will be probably the weak link? Trust me, i am a clutch killing expert!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
