Greddy E-manage Blue - Was on my R33 Series II, for 3 months before I did full rebuild & changed ECU’s.
Easily installed, as it comes with Loom Harness for R33 S2 RB25, meaning direct plug n play without cutting any wires. In Original box and instructions, Once installed it is like driving a new car as it comes with preset tuning. I originally bought this through the local Autobarn in my city.
Looking for $280 ono
UNIT INFO:
All the instructions etc are available from the Greddy website.
"The e-Manage Blue is an inexpensive programmable fuel management system that allows you to properly tune your factory fuel system without having to change the entire factory ECU system to an expensive stand-alone unit. The e-Manage system is a universal piggy-back type unit which taps into most Japanese factory ECU wiring, by utilizing the existing sensors. Basic functions will allow the user to slightly alter factory injector duty-cycle (+/- 20% at 5 preset RPM points) by intercepting and altering airflow or MAP sensor signals.
There is a 16x16 airflow adjustment map, larger main injector correction adjustment, upgrade air flow meter adjustment, boost limiter cut, anti-engine stall, VTEC-fuel adjustment, real-time map trace, real-time display, real-time communication and basic Data-logging. With the use of our Optional Injector Harness and the software, the unit has the ability to control an additional 16x16 injector duty cycle map and the controls for adding up to 2 additional sub-injectors. If the Optional Ignition Harness and the software are used the unit has the ability to control a 16x16 ignition timing map. All of the above maps can also be map-traced in real-time as well."
  • 2 months later...
  • 5 months later...
