All.
I have for sale my spare RB26 as per below. Comes complete from sump to turbos which are HKS 2530s (pics included).
I've had this motor for quite a while from a GTR I had imported a few years ago. I was planning on putting the motor into a side project, which has now been canned in favour of buying a house.
Don't buy a stock motor for $3500-$4000 and then spend another $2500 upgrading turbos, Simply bolt this great condition motor in, wind up the boost and see a easy 360-400rwkw with the rare and much sought after HKS 2530s :thumbsup:
Details as follows:
- Motor came out of a running '96 R33 GTR with ~120,000kms on the clock. Dyno'd up and drove fine with around 280rwkw on 12psi from memory.
- Motor was comp tested immediately before taking it out for storage, results returned 155psi-160psi across all cylinders by Racepace Motorsport, well within factory tolerance.
- HKS2530s & set of split dumps are on the motor.
- Plenum has a new gasket/resealed as there was a slight leak.
- Plenum & cam covers have been freshly crinkle coated.
- Low KM R34 GTR stock injectors installed, freshly flow tested/cleaned. One of the stock R33 ones were leaking, so full set replaced.
Price: $5500 compete
Price for motor (minus turbos only): $3100
Happy to ship interstate at buyers expense.
I will separate turbos/dumps & motor. PM for further pricing & discussion.
post-709-0-25258600-1339658710_thumb.jpgpost-709-0-08875900-1339658716_thumb.jpgpost-709-0-05024100-1339658722_thumb.jpgpost-709-0-68919400-1339658727_thumb.jpgpost-709-0-71689400-1339658732_thumb.jpg
Contact via PM.
Thanks
https://www.sau.com.au/forums/topic/402550-hks2530s-w-complete-r33-rb26-engine/
Still here.
Will consider splitting up the Turbos/Dumps & the motor
If interested in either part - PM me. I will only split once i have deposit for each part.
Not likely to be around that long.
Have a buyer for the dumps.
Potential for the turbos (if the motor goes)... So just need a buyer for the motor and it’ll be split up no problem.
First to cough up cash, wins!
Sure is.
Lots of PMs, lots of low ballers - the price is very reasonable for what you are getting, you don't find cheaper.
So don't bother sending a PM if you intend to ask for "best price". The best price is listed given it's priced to sell.
Turbo & dumps are sold pending pickup later in the week.
Motor here now - $3100 ONO
Comes with all the oil/water lines for turbos and full intake/exhaust side still. Literally just minus the turbochargers.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
