Hey guys,
I noticed a pretty bad chip on my V recently, but its in a really strange place.
Do you guys know what could have caused it?
The only thing I could think of is that I was parked on a fairly busy road (only a 60KM speed limit) and a cars flicked a rock up somehow.
I couldn't imagine something being able to spin around the wheel and release at that point.
It also seems like the object has hit my bumper twice (wrapped around?).
I'm fairly certain it's easily repairable, just annoying.
hey mate i have one as well its from stress the front bar would have scraped and bent and the paint would have cracked and flaked off. mine is almost identical but a bit higher with less cracks.
  • 3 weeks later...
Completely off topic, those Vertini wheels. Mate how do you rate them? after seeing yours i'm seriously considering getting a set. I was looking at Verrstoen's for about $1500 a set but an extra $500 gets me 20" and FAR better looking rims. Let me know!
They're not bad wheels. They look the part. I'd say they're a bit on the heavy side - but if you're going for looks (and if you're look at 20s) then it doesn't really matter how much they weigh. If you can find me a set of 370z 19inch Forged Ray's i'll be happy to sell you mine :D
I'm getting the rear two replaced next week (clear seal is peeling, apparently not normal - free of cost of course) and putting new tyres on. I'm just a bit tired of looking at them now, feel like I need a change.
A better pic of the rims:
Edited by sheldon2369
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
