I have been noticeing build up of coolant on the ports at the front and middle of the intake manifold as of late and it built up so i decided to check it out.
With the intake manifold off i cant really notice what has cause this although i can see it has leaked directley above the channels where the coolant goes inbetween port 1 and 2 and port 3 and 4, ...... 5 and 6 are fine. I dont think these intake manifolds are common for warping and the feeler guage shows it fine.
The only thing i can put it down to is orange goop was applied only around the coolant channels on the gasket and i though this might have caused the leak of coolant as the workshop manual says you dont need to apply anything as its a crushable metal gasket for the intake. A non genuine gasket was used aswell =/
Has anyone had this problem before? Should i re apply something there or should it just be crushed?
The engine was rebuilt 25,000km ago and not had a problem, the coolant only started leaking 200km ago ......
You can see where the coolant has stained
Hey Jez, What are you using with metal gaskets, i still feel the need to put something there..... im now being told to use Permatex Aviation Form-A-Gasket No. 3 Sealant
Permatex Aviation Form-A-Gasket No. 3 Sealant IT IS!!!
im changing everything anyway all the gaskets, 8 coolant hoses/heater hoses around there the 4 air hoses and 13 bolts and nuts on the intake manifold and the 9 on the plenum just to be safe ;)
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
