heya guys im selling a complete rb25 package
from a 1996 series 2 with 120K km's
rb25det (currently without turbo but a stock turbo can be included at added price)
5 speed manual
clutch (believe to be stock)
engine loom
ecu
afm
i pulled this out of a wreck to use in my track car compression around 160psi throughout, i picked up another wreck that has heavy duty cutch and spitfires with same compression so easier to sell this running gear as its already out the car :P
i have to confirm the turbo specs on this other rb25 and that turbo can be included in this deal at a added price
$2000o.n.o
package is in northern suburbs S.A
pm if interested
also stripping series 1 r33
http://www.skylinesaustralia.com/forums/topic/402639-1994-r33-gts-t-manual-wrecking-black-front-hit/
**************$1700*************
yes thats right last price drop need it out the way so i can get the wreck gone aswell and put my s14 back into the garage out of the weather :s
you get great condition series 2 RB25, 5 Speed gearbox, clutch, loom, ecu, afm and will chuck in a pod filter :P
I'm looking for a box, i'm in brisbane however.. I can organise freight not a problem, are you willing to separate?
Give me a call between 0630 - 1830hrs 0438 073 151 Cheers :D
