heya guys im selling a complete rb25 package
from a 1996 series 2 with 120K km's
rb25det (currently without turbo but a stock turbo can be included at added price)
5 speed manual
clutch (believe to be stock)
engine loom
ecu
afm
i pulled this out of a wreck to use in my track car compression around 160psi throughout, i picked up another wreck that has heavy duty cutch and spitfires with same compression so easier to sell this running gear as its already out the car :P
i have to confirm the turbo specs on this other rb25 and that turbo can be included in this deal at a added price
$2000o.n.o
package is in northern suburbs S.A
pm if interested
also stripping series 1 r33
http://www.skylinesaustralia.com/forums/topic/402639-1994-r33-gts-t-manual-wrecking-black-front-hit/
**************$1700*************
yes thats right last price drop need it out the way so i can get the wreck gone aswell and put my s14 back into the garage out of the weather :s
you get great condition series 2 RB25, 5 Speed gearbox, clutch, loom, ecu, afm and will chuck in a pod filter :P
I'm looking for a box, i'm in brisbane however.. I can organise freight not a problem, are you willing to separate?
Give me a call between 0630 - 1830hrs 0438 073 151 Cheers :D
    • @GTSBoy are your spam bot senses tingling too?
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
