heya guys im selling a complete rb25 package
from a 1996 series 2 with 120K km's
rb25det (currently without turbo but a stock turbo can be included at added price)
5 speed manual
clutch (believe to be stock)
engine loom
ecu
afm
i pulled this out of a wreck to use in my track car compression around 160psi throughout, i picked up another wreck that has heavy duty cutch and spitfires with same compression so easier to sell this running gear as its already out the car :P
i have to confirm the turbo specs on this other rb25 and that turbo can be included in this deal at a added price
$2000o.n.o
package is in northern suburbs S.A
pm if interested
also stripping series 1 r33
http://www.skylinesaustralia.com/forums/topic/402639-1994-r33-gts-t-manual-wrecking-black-front-hit/
**************$1700*************
yes thats right last price drop need it out the way so i can get the wreck gone aswell and put my s14 back into the garage out of the weather :s
you get great condition series 2 RB25, 5 Speed gearbox, clutch, loom, ecu, afm and will chuck in a pod filter :P
I'm looking for a box, i'm in brisbane however.. I can organise freight not a problem, are you willing to separate?
Give me a call between 0630 - 1830hrs 0438 073 151 Cheers :D
    • No. Only for a standard ECU with/without Nistune. Standalone has no need for it. That's like the 3rd time I've said so.   And as to that sensor linked - yes, it does look like it would be the right one. I've never bothered to see how available they were - just assumed that they'd be hard to find. I think I'd be planning to go Link ECU rather than buy sensors I don't actually want to make Nistune work, if I did not already have Nistune. As you do not already have Nistune, you should realy consider your options.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
