I rate this comment.
She comes on here for advice and just gets the usual SAU user's 'we're awesome n know everything, you dont-noob' lines without any real help or guidance.
If you read back over the comments you'll find only constructive help and advice for the first half until the person decided to be obnoxious about it. Then the usual stuff started....and rightly so
The person also had their name as Alf originally and signed up with their first post as the top one for this thread. Later changing name to Jennifer. Second accounts are frowned upon I thought? Can we get an expose by a mod?
Guess it kinda sucks to try and have two accounts from a static IP address, and using a very similarly named email address
It means I know what your other account is... And as your other account is a reasonably new user, with reasonable threads...
This surprised me.
