hey guys upgrading to the double din wif screen subs etc lookin at settin me bak 3g+
Therefore selling the ipod integation set up. Bought from CHRIS ROGERS at AUDIO EXPRESS BRISBANE $300+ roughly. Only had in v35 for 3 mths. QUALITY STUFF
Sounds amazing through ipod/iphone etc
Charges your phone insanely quick whilst playing your songs!!
$150
https://www.sau.com.au/forums/topic/402898-ipod-integration-chord/
Yeh exactly right. It allows you to play straight from your ipod/iphone at the sound quality of a cd if not better. Perfect for those guys that dont want to spend 3k on an audio set up but still dont want those shocking fm transmitter quality of sound.
I have a 2 yr old iphone and it charges it to 100% in about 10mins. Also stops if you receive a call to allow you to pick up your call. Can still browse safari, text and everything while it plays.
Check it out on google, they are a good solution for someone who wants clear sound audio but doesnt want to spend the big $$ on replacing the whole original set up.
Only selling because wana put mine in some car shows as of next year so yeah want to spend some big $$ on the audio setup.
  • 1 year later...
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
