I'm currently in the process of removing weight from my weekend and track driven 32 GTR. I've already taken out the air con, rear wiper and some little luxury things that I didn't really need. Now I'm thinking how far I should go with it. Removing the rear seats and sound deadening has crossed my mind but I don't really want to ruin the car I really enjoy driving on the road.
My question is, how far have you taken the weight loss in your street and track driven skyline and did it ruin the comfort when driving on the street.
My weight savers so far, are...
9Kg Ti exhaust
1Kg C/F Rear wing blade
4Kg Ti front strut brace
You've already mentioned other N1 eliminations; but the R32 GTR N1 also dispensed with ABS eh? Are you game enough to remove sound system, speakers and ADR child restraints too?
Depends how much street use, the sound deadening and carpet prob around 30-35kgs+-???, the back seat is pretty light, under 10kgs, they're pretty loud inside with it all out, especially with big exhaust etc, for me for st leave it in, if more track and winning is winning take it out
Yeah i had the interior out for a while, it wasnt only the noise that annoyed me it was the glare off the white in the sun.... I stripped all mine and put a cage in, never bolted it down then had a change of heart and put the full interior back in...
rear steering, I removed the whole thing right to the pump including the pump wheel, about 25kgs
inside sound deadening, 9kgs, not worth the effort on a 1400+kg car and makes the car horribly noisy to drive on the street
Ok I think I'll leave the sound deadening and the seats in then. For a 9kg loss I don't think it'll be worth having all that road noise. Hicas has been removed a while ago. Same as rear wiper, air con including core behind dash (never use air con so removed the lot), rear speakers gone, I 'm planning on removing the abs soon too.
Anything else people recommend to remove on a street and track driven skyline?
Biggest weight saving factor... Dont let girlfriends in the car hahaha.
Terry dont tell Kinberley i said that :P
You would never drop Kimberley off to lessen the weight. And if you did, you also know there'd be ten other guys hanging around to pick her up :)
Abouts time you knew how to spell her name too ;)
Lol > that part, I can tell her!
Baaahahahahah.
Damn fast typing and not checking.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
