Rb20/rb25 Intake Pipe (Alloy Or Sillicone) Nsw Please - Few Other Rb20 Bits
After an alloy or sillicone intake pipe.
Will be going on a RB20 which is running an RB25 turbo.
NSW only please.
Also after:
RB20DET TPS
RB20DET AAC
RB20DET IACV
Or if anyone knows others that would fit the RB20, please let me know!
Hi mate
I have these parts for sale
RB20DET TPS
RB20DET AAC
RB20DET IACV
Ill do all 3 for $100 including postage if your interested...
I might have, Peter :P
Can you PM me your address please ! Will come tomorow morning if that's fine, will be up all night/morning to watch Spain vs France haha.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
