  • Replies 59
Mate I know they are here somewhere but I just cannot find them. Hopefully they will turn up soon, if they do I will let you know ASAP
okay thankyou
  • 4 weeks later...
  • 4 weeks later...
Injectors sold
Other parts still lying around and I want them gone. Text or call 0420 593 194 and let me know what you are after. I am flexible on price and want to get rid of these parst
cheers
  • 3 weeks later...
Just an update on what I have left
Rear Brake Discs
Rear Calipers
Dash
Windscreen wiper motor
Tail lights
Various interior parts and trim
Centre console
FLHS and FRHS window glass
Rocker Covers
Rear Seat
Other bits and pieces.
Contact me on 0420 593 194 and let me know what you are after
cheers
More parts I found in the shed:
Middle rear seatbelt............................25
Stock ECU..........................................75
Airbox.................................................50
Interior quarter trims...........................75
Cluster Surround................................60
Fuel tank door....................................25
Pod filter with adaptor.........................30
Reverse lights....................................50
Ring or Text 0420 593 194 :action-smiley-069:
Heaps of spares still available. let me know what you are looking for - I really want to get rid of these as they are simply taking up room in the shed.
PM, ring or text 0420 593 194
cheers
  • 8 months later...
  • 1 month later...
Yep still got heaps of parts availavle folks. Dash, rear seat, tail lights, rear breakes, interior bits, rocker covers and heaps of other bits and pieces. Let me know what you are after and Im too easy on price....I simply want them gone
  • 4 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
