hey guys im tossing up wat to do atm, my 33 lost reverse yesterday atm all it does is make a whinning noise.
A mate of mine rekons the box is cactus, so im keen to toss a manual in it. but i need to buy some time so i can find a manual conversion for the right price. and ive noticed you can pick up an auto box for next to nothing.
I dont wanna pay more than grand for a manual conversion tops im prepared to go to $1200.
i guess wat im really wanting to kno is wats the better box to run for the money, and if theres anything i can do the get somthing out of reverse till i can get a conversion
https://www.sau.com.au/forums/topic/403149-r33-auto-box-slipping-in-reverse/
there was a guy in coomera parting an r33 det wit a manual box he had 800 on the whole conversion, i jus missed out on it. ive seen a couple around for resonable prices.
theres no way a manual gear box is worth 2500 for a skyline when ive seen auto boxes from $150 to $500.
ive seen whole half cuts for 3k it makes buying a manual converson on its own pointless if a half cut is only another $500
i figure if i shop around one is bound to come up. but if i have to in the mean time im guessing ill get a cheep auto and bang it in for the moment.
Edited by top13s
A good box should be more than $1000 on it's own. Maybe with clutch and flywheel, maybe not.
Auto boxes are worth nothing because......they're worth nothing. People actually want manuals, hence the $$. A full conversion, including the pedal box, clutch master, necessary transmission mount, and gearbox loom/engine bay driver's side loom, plus the work to put it in, adds up.
True didn't think of it like that. But still I'll hunt around for a conversion cheep. There out there. If I'm gonna spend 2500 for one I'll buy a half cut for the bit extra.
I am thinkin of gettin another auto in the mean time
comparing the price of an auto with a 25 box? really? really?
the only cheap 25 stuff i've seen was 20 stuff that people were trying to fob off as 25det, 25de same as 20
we haven't got any 25 manual half cuts going for that price round these ways
gonna do the conversion wit the help of a mate, and i have a manual conversion for less than a grand ;) only one catch tho were not sure if its a 32 or a 33 conversion. they guy dosnt kno :S but i got it really cheep. (i havnt picked it up yet tho) but i figure if its a 33 conversion SCORE but if its a 32 box im not to worried it will get me converted to manual and ill get a 33 box when one comes up.
i jus need to kno just incase its a 32 conversion, does the pedal box fit a 33 and will the tail shaft work on a 33 4 door a mate of mine seems confident it will all fit bar the pedal box says hes unsure lol.
also how can you tell between the 32 manual box and the 33 manual box
The tailshaft is completely different. The speedo drive is completely different. The R32 box is physically half the size and 1/3 the strength of the R33 box. Do not fit it behind an RB25DET.
If the seller "does not know" if it is a 33 or 32 box, then you can be sure that it's a 32. Don't do it. Don't do it.
this, the clutch pedal is different, can be made to fit, 25 box has lever mounting on a slant with torx style bolts, 20 just flat with a 6 bolt plate, otherwise pick it up & shoulder press it, if it's a 25 box you'll make a keeeeeyaaaaaaahhhhhhhhhhhhhh!!!!!!!! noise
kk wells im thinkin its a 32 box atm ill have a look at it on the weekend, to be sure. there was one on the goldy for 800 but i missed out on it. ill keep an eye out and i also kno a bloke who may kno some one who has one to if this one falls thro
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
