How can someone vandalize such a beautiful piece of machinery :(
This is going to make me very concerned when I park my car. :/
Unfortunately it happens all too often, mine was done under the drivers door handle down to metal and there are lighter scratches on the bonnet..... Both of dads cars have been keyed too (separate time and location)..... Its almost impossible to avoid low life plicks these days BUT do everything you can to protect your pride and joy :/
I feel sorry for anyone who has their vehicle damaged by kids.
I'm so careful nowdays my GTR is either within my line of sight or locked in my garage. :(
It's a shame you just cant drive wherever and park. Limits the time you get to spend with your nice ride.
I also drive a shitter almost everywhere because of these karnts.
Back in the day peeps would just admire a nice car.
To bad we took these awesome cars out of one of the most respectfull places in the world and brought them to Australia. Where we cant even leave our cars in a carpark of a shopping centre without fearing it would be stolen or keyed up by some tosser. If i were to personify our cars i bet they feel like they been taken out of sweeden and brought to serve in Afganistan !
Those who have nothing are jelous of those who do. Hence the vandalism.
There is a generation who believe everything should be given to them and they should'nt have to work for it.
If you don't work hard and earn it you dont appreciate or respect the efforts of those who do.
Some of us have raised a generation this way, unfortuantely.
Will your elderly (& deaf) next door neighbours allow you to park on their property (& you supplement their pension @ $3/wk)?
Their properties isn't suitable to park a skyline. On one side, it's a shabby rotted wood garage and on the other, there isn't a garage at all, weeds growing everywhere. My front yard is concreted and could accommodate up to 6 cars, just that my garage is rented out to a guy who rents my granny flat and he uses it as storage. His car is currently parked out next to mine, which gives me a bit of cover from the wondering eyes but hopefully my new slat fence would give my 34 bit more privacy. Might invest in some CCTV cameras.
Hate hearing stories of idiots doing shit to people's cars. If it was unprovoked i would be confident to say it was a very jealous individual and/or group as you have a gorgeous looking car on your RED P's. Haters gon' hate.
And yeah definitely sort out that garage man, i am nervous about leaving my V35 in the street for even a few hours at my house even though i live in a very safe area with next to no crime. Camera's at your house would be a great idea too man,
i had my old 33 keyed, if you have something nice lock it away its a shame but its what you have to do, i find its to do with the politicaly correct parents now days, when i was a kid you feared no one more than your parents if you did something worng God help you for the floging you would get would be worse than any jail sentence.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
