Hi Guys,
I've searched and searched this topic endlessly on this forum and on the web but I can't find any straight answers.
Can you guys advice on Braided Stainless Steel Brake lines for my 2003 V35?
Questions I have are:
1) Is it 4 or 6 brake lines that I need?
2) Is the 350Z kit the same as the V35?
3) I assume the kit for the G35 is the same as the V35?
4) Does anyone know if I buy a reputable kit from Ebay/US e.g Goodridge/Stoptech/HEL would still be ADR approved? I know the HEL website specifies you need to select ADR Compliance when shopping. Btw, the HEL website does not have the specific kit for the V35. Closest is 350Z - hence question 2.
5) Would Brembo or Non Brembo brakes have any impact on the type/number of brake lines?
I really appreciate any comments/advce/experiences on this! Thanks!!!!
https://www.sau.com.au/forums/topic/403459-braided-brake-lines/
Yes G35/V35/350Z are identical in terms of Brembo brakes. From memory there are 4 lines. I bought StopTech braided lines and they are good. Not sure if they are ADR though - but they do have whip test stickers/high quality ends - is a cop really going to pull you up on this? But I guess if you ever got defected it matters.
regency in SA is harshly against braided lines. their reasoning is: you cant tell if the rubber core has cracked or perished.
i did hear that there is a brand that is approved.... dont know if thats just a rumor tho
Lol, teflon won't perish like rubber. There is no law telling the owner to replace 40 year old brake lines but new replacement braided teflon ones don't pass? Regency are a pack of knobs.
As long as the lines are ADR approved and marked as such you should have no issues.
No a cop won't but if u get into a accident and it's something due to brake failure.. U R IN BIG SHIT!!!
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
