rb30 timing belt tensioners
could this be done, running both tenseioners above the water pump hpw nizpro done on there hybird motor
what belt would be used on this setup
block only has 1 flat machined hole left side-
wit oil/water lines
engine from granny vl 120,000km
series 1 block
pic below
https://www.sau.com.au/forums/topic/403690-rb30-timing-belt-tensioners/
Yes it COULD be done but i don't see any benefit over simply relocating the left tensioner as everyone else does. The only benefit to that setup would be the possibility of removing the cam gears and changing cam timing without removing the balancer and bottom cover, but it'd probably take longer to figure it all out and relocate the second tensioner than you'd ever spend taking a balancer off.
yeah you could, you would just put the left one where the measure marks put it then put the other one in a similar place on the other side ( you just have to make sure the belt won't hit the CAS bracket ), then get a old 26 belt cut it then run it around everything so the two end end up on one of the cam gears and count the teeth in between the two ends then search for a belt to suit
this sit is a good place to start to find a belt http://seekpart24.com/search?am=audi&c=100404
  • 9 months later...
http://www.skylinesaustralia.com/forums/topic/15420-r33-rb30-conversion/
Try these
has anyone got the actual measurements for tapping twin tensioners above the water pump?
