Hi All,
Applying for an exemption in QLD to drive a 4 door R32 GTS-T as it falls below the 125kw/tonne ruling.
The exemption states i must supply a
- "Copy of a document published by the vehicle's manufacturer showing the vehicle's kerb weight and maximum engine power. For example, an owner's manual, a letter on the manufacturer's letterheard, or information from the manfucaturer's website.
- a specification information test report, issued by any automotive service provider that has the appropriate equipment, if a document published by the vehicle's manufacturer is not available.
I know that the car weighs 1290kg and has 158kw from factory (122kw/tonne) but i cannot for the life of me find anything on the nissan website or any sort of specification sheet to this fact.
if anyone has a brochure or some sort of sheet to the above requirements i would be forever in debt!
I'm not sure what the limitations on the supporting documents are and don't want to send it off and get it back 2 weeks later to have it fail.
Owner manual with kerb weight + max engine power would suffice.
Thanks
Edited by astorey
Page 23 from the workshop manual has the various engine outputs, 215Ps is 158kw.
The kerb weight will be difficult as these cars had options, HICAS, sunroof to name a few.
I've seen wildy different weights quoted from Wikipedia etc.
Might be easiest to put it on the scales and tender the weighbridge docket.
  • 7 months later...
Hi I was just wondering how you went with your exemption and what paperwork you ended up using?
I'm looking to apply for one for the same model myself so trying to find out what's best to use as even RedBook doesn't have the full specifications.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
