Hi Guys,
Thinking of repainting my Black V35. Thinking of sticking on to the black but would like some suggestions of better colour options(with photos if you have). Also what are the questions that i should be asking like what type of paint should i use and other info. Could someone give me rough price for the job.
Thanks a lot guys.
https://www.sau.com.au/forums/topic/404273-v35-repaint-tips-and-suggestions/
  • 1 month later...
hey guys, few questions....cheap and best place to buy the paint in Brisbane...or do you think i shud order online....secondly is clear coat optional and do i need to buy some premium thinner for the paint...
buy the paint online? you are not going to try and paint it your self right? and clear coat, of course !!!!
$2500 or more for a respray from someone cheap..
$2500?! Would have thought that $4k would be a more appropriate number - for a decent job with proper clear applied that is.
Agreed, I had the turret (hood), and boot lid resprayed in another car a few years back now, and that was $900 - wasn't triple layer pearl paint either.. You can probably add 50% more if you want a pearl coat.
$2K would probably only get u a taxi paint job. i.e.: door jams, engine bay etc untouched. A proper paint full respray would cost you $5K++++++
so true i.e Sheldon's ._.
i would recommend just go BLACK so just in case unseen accidents color matching will be a breeze
i got a mate that goes car wrap pm me i can give more info on facebook
f**k off, my paint job is awesome - 3 layer pearl for 2k (Usually he does it for 4k - 5k). Not painting inside the doors / engine pay isn't the biggest deal, my cars white, inside my doors are an off white - in no way is my paint job a "Taxi paint job"
Even if I had 5k to spend i'd still rather spend 2k to get what i've done. I would change nothing about my car.
Edited by sheldon2369
Black is one of the worst colours to go with, although it does look amazing on most cars. Attracts heat and if you live in 25-30 degree heat every day you don't will suffer.
Scratches come up horribly and is very difficult to maintain, but if you take care of it and don't mind the extra heat then it can turn out being a very good investment.
You haven't changed colour mate. Pearl white on white is a pretty breezy job - compared to changing the colour all together.
Ever seen those cabs that are orange outside and inside is all blue still.. lol!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
