Hey hey hey
Ive always wanted to try the Subaru upper engine cleaner. Heard of them being used on subies, evo's, vw's. So why not get rid of some carbon build up in the gtr?!
Bad idea? Please tell me why?
Yes I have searched, yes they are all in 2006 and one I found was in 2003 lol.
Question time. Where do I spray it? Do I take my intercooler pipe off the plenum and spray the first 1/2 of the can in there? Then after that where do I spray while its running?
Thanking you.
https://www.sau.com.au/forums/topic/404398-lets-talk-upper-engine-cleaner/
So far,
  • Do it before a oil change
  • Spray 1/2 the can in each individual cylinder (thanks silvia guys)
  • Do the other half while the engine is running through a vac line
  • Make sure it is well ventilated (some videos are crazy haha)
  • Get it from Subaru dealer
  • The more smoke the dirtier your engine was
  • Its the ducks nuts
id be interested to know if anybody has had any bad experiences with it...
anybody?
i used a can on my old sonata and it seemed to make it smoke even more and use more oil.... (tho its got over 250k kms on it n they are shit engine...)
Still got a can sitting in there so wondering if i should run it thru the RB25...
turbo seals? O2 sensors? high flow cat?
Nulon upper engine cleaner is cheaper.
Warm up the engine first. Turn it off and spray it in all hoses leading to the manifold and AAC. Let it sit. Crank engine and it will start in 5 seconds or so. Repeat.
You'll probably need to reset your idle. I even had to change my cold start values.
The subie stuff is only $18 per can. Did it f**k your cold start valve? havent heard of the subie stuff needing to reset idle nor taking out the cold start valve. Maybe this is a skyline thing
been thinking about this stuff as well, think I'll see what my mechanic thinks next time I'm in there.
Some Mainlube engine flush probably wouldn't go astray either for the oil system!
I like your thinking. Let us know what your mechanic says
i used some in my vt commodore (had about 210,000kms on the clock at the time, and has nearly 245k on it now). other than making it smoke like a sumbitch when i started the car again (until it burnt it all away), it didn't actually do much. i pulled the intake plenum off afterwards and it was still sort of caked on so i scrubbed it clean with some carby cleaner and degreaser. didn't make any difference to how the car drove though.
I've used this sort of thing many times in a few different forms (ie nulon, wurth, AC delco etc.) and so far have found the subaru one to be the most effective. The main thing to BE AWARE of is that i believe the fumes are carcinogenic, so ALWAYS be in a well ventilated (preferably outdoors) area, and use caution while spraying. Aside from that, follow directions on the Subaru can, and have an explanation ready for when the CFA arrive :).
  • 1 month later...
its also rubbish compared to the subaru stuff, i use the subaru stuff in everything
yeah iv never noticed a difference after using it.
Only difference i ever noticed was a bad one. Used it on a 2.0 4cyl Sonata with 250k on it. It blew a tiny bit of smoke beforehand and used a bit of oil. After some upper engine cleaner it blows smoke like a mother f**ker, especially from the valve seals (i pity the people that are behind me at the lights after sitting for a while) n it uses bulk oil now.
Never again.
The only time i can think it would be a useful product is as a repetitive preventative product in motors that are prone to build up. Otherwise its probably not going to move anything substantial (like injector treatment) and if it does itl probably create a problem in a car that is otherwise running ok...
Edited by jjman
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
