Hey so I want to install an amplifier in the boot of my r32 gtr and ive seen the thread for an ampliifer install into a r32 gtst which was heaps helpful but the problem I am having is that I dont know where to run the power cable of the amp through the firewall. Ive heard your meant to run it through the firewall on the drivers side but there is something in the way which makes access to the hole nearly impossible to access. So I was wondering if there is an easier way to pass the power cable for the amplifier through the firewall, any pictures would also be greatly helpful.
https://www.sau.com.au/forums/topic/404587-help-with-r32-gtr-amplifier-install/
Something in the way,
On which side? engine or interior?
Cant you take it off?
I had to take off a plastic cover under the dash,
you can use a piece of stiff wire to start it through
or the thin strip of metal on wiper blades is really good,
this helps as there is foam and tape to get through.
Yeh there is something in the way. On the engine side though I am not quite sure what it is. Yeh i know about that plastic cover and have taken it off and seen underneath it.
But as you can see from the photo something is annoyingly in the way and seems to be riverted on so i dont know to move it and i dont know if you can tell but the wire grommet is right underneath it.
  • Like 1
jack up car. remove drivers front wheel, inner guard, radiator resevoir , run wire to front of car via access point behind resevoir tank,
reassemble. done.
  • Like 1
Thanks Chris Rogers, I did exactly that today and even thought it was a bit of a bitch it all worked out and now i have a power cable running from the battery and through the firewall. For anyone else curious about this problem, I feel like in an r32 gtr this is the only solution and there is no easier way but the good thing is its not too difficult and could easily be done in less than 90 minutes
  • 1 year later...
Cheers guys this thread is a huge help.
I was reading up another one which showed the hole unlike like mine and the picture by dean20 which had the plastic cover in the way.
Will follow these instructions tomorrow however my splash guard plastic screws are stripped and I need to get them out somehow :\
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
