so....this sound happens, sort of like a crunching noise. it happened when the car was off one day, and now its progressively gotten to the stage where it does it when the cars runnign now, and the car runs like a slug. had the car almost a year and i can honestly say ive never had it running properly for a week. can anyone tell me what this is so i can fix this POS once and for all???
it would be SO good if i knew what the problem was so i can fix it....
cheers
http://soundcloud.com/matt3429/shitty-skyline-sound
https://www.sau.com.au/forums/topic/404594-sound-bad-performance-what-next/
More details needed.
Does it increase with rpm?
Does it still happen with clutch in
Does it happen straight away on start up or after a few seconds.
Post a pic of ur engine bay. It sounds like a rotational noise from the fan or belts etc
same noise all the way through the rev range, doesnt get louder or quieter, sounds like its coming from the front of the engine i cant pinpoint it because the fan is spinning and will take my head off lol....happens with the clutch in yes, sometimes straight away other times after a bit.
Try removing the auxilary belts from front of the motor and start the engine. See if the noise is still there.
Also try using a stethascope of sorts to pinpoint the noise.
Has the timing belt been replaced?
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
