  • Replies 142
Yeah that's right 89cal these boys are trying to tell me that a 02 can't cause a lean mixture and you yourself no they can but most the time they cause a rich mixture I've seen it right In front of my very own eyes I've even got a damaged 02 sensor with my right now that I can 100 % prove with make a rb26 run lean
Yes cause it reads way out of limits and runs lean mate I've tried as well :) you no yourself they can cause a lean mixture when cruising simple as that I'm Finished thanks for that
Edited by Hot33r8723
No I'm telling you it wont run lean enough to melt things. It wont let it go over 15.4ish:1 AFR till the ECU takes over and pulls it back.
I'm not sure how the GTR's work but I'm guessing 1 O2 sensor for each 3 cylinders, so you may end up having it drive weird at cruise or fouling plugs in 3 cylinders, but I honestly dont think it could run lean enough to melt things
I run 15.7:1 AFR's at cruise with no issues. Some days they even get up around 16:1 for whatever reason, and my engine is fine.
I think your problem might have been your fuel pump as originally thought....
Yeah gtr one sensor for 3 cylinders and if your air flow meters resistance is out of whack as well as a damaged 02 put them together and watch them
Front 3 fry away but hey 89cal your the first person ive spoken to that actually no what there talking about an yeah I never believed the o2 would cause a lean mixture I always thought rich cause it throws a code to the ecu an depending on how your afm reads Aswell can cook cylinders
Not exactly. The 02 sensors signals are halved by the ecu. Not 1 afm per 3 cylinders.
And with the 02 sensors im pretty sure the factory ecu is batch fire so it cant physically lean out cylinders unless and injector is playing up
But any way I've got a Walbro 255 now it's a bit loud in the back end what u think about the direct feed mod do you think it's
Worth it
Definately worth it. Wen u see the flow gauge before and after a rewire it the flow goes off the gauge when rewired
Is there any real benefit in doing this with a Nismo/Tomei fuel pump?
Been thinking about doing this for a while but not real sure if its worth it
Each airflow controls each 3 cylinders I don't know about the other pumps
How can the AFM's control each three cylinders when the intake joins into one pipe before it gets to the intake manifold?
Air metered through turbo 1 joins with the air metered through turbo 2 after the intercooler, so air from turbo 1 doesnt necessarily go to cylinders 1-3, it equally spreads between all 6
So what if I run the stock wiring and don't do the direct feed mod ???? The pump wouldn't run at full capacity right ? But a Walbro needs minimum 12 volts and there's a voltage regulator that ups the voltage when revs are raised about 3000 grand right ? So the pump would be working overtime doing the direct feed mod and as Walbro says minimum voltage 12 volts and the specs of the pump would have been tested minimum 12 voltage other wise Walbro would look ridiculous for making fake claims the best thing to do is purchase a hot wire earth kit for your whole car not just up the voltage to the pump
Nah man ur 100% wrong :rolleyes: ...... Sarcasm
On a rb26 the airflow meters are before the turbos mate senses the air
Flowing through the front of each turbo and signals is sent back to the ecu telling the ecu how
Much air is flowing into each turbo and each 3 cylinders I work for tony rigioly mate
Both turbo's end up flowing air to the one point. There is one intake manifold that joins all 6 cylinders
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
