any body know where to get any purple backlit or led lit gauges? boost oil press water temp etc? ive spent hours trawling thru ebay etc, any one else got any ideas? (ps there isnt really an interior section to post this in but feel free to move it where you want!)
https://www.sau.com.au/forums/topic/404913-purple-lit-gauges/
Cheap Chinese crap but they work.
Google autogauge / autometer they come with white then when you put your lights on they change to orange. (depending how you wire it up)
Pretty certain you could pull it apart and put in any colour LED you want.
Or if they are stock gauges, it's just a few globes that you change.
neons? god no! thats a good point could just pop a resistor and an led in there if there is no direct replacement bulb.
(the missis loves purple, gotta keep her happy or i wont be able to spend any money on it!)
http://www.rocketindustries.com.au/
looks to be the only australian distributers for autometer.
thanks sydking much appreciated! id love defi, but they are so expensive its crazy! (well to buy from an Australian distributor anyway)
$700 delivered from i think the only australian DEFI distributer.
Thats for the single DIN trippe guage cluster. ( im not keen on dash mounted ect)
thats about 500 more than i want to pay! yea im going 52mm to put in a custom din slot from an old car of mine. if you look at international seller think you can get the defi din for about 550 -600
true, but i think id rahter pay a bit more to deal with an australian company, If anything goes wrong good luck contacting people in japan/china.
I agree they are pricey, But when youve spent 25K+ on mods what another 700 odd for peice of mind that your readings and warnings are as accurate as can be.
Ive done plenty of searching for a cheaper option though none seem to stand out.
Another one to look into is http://www.flyn.com.au/saber%20gauges.htm
there a lower end guage like autometer, But made in Australia.
fair play! if had the money to spend 25k on mods id be wanting top end gauges, 100% and i guess expense is in the eye of the buyer! im not Australian so i have no loyalty to aussie sellers, i have and will continue to buy "locally" if the customer service is good and i can find value for money. however to find both is very rare. i understand companies have to make a profit on items, but most of the items i find are from china/japan! ill check those flynn gauges out now see if i like em!. thanks again for all your help sydking much appreciated!!
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
