As car is sold I'm cleaning out the bits and pieces I have left over.
All items are rare and generally hard to come by, all in great condition.
  • R33 GTR Top Secret Carbon rear diffuser
    Condition: Used. Still in very good condition overall given it sits under the rear of a car that you'd drive. No actual cracks, it's all surface/coating marks/cracks.
    Price: $450
post-709-0-51852400-1343510911_thumb.jpgpost-709-0-52657400-1343510919_thumb.jpgpost-709-0-30416900-1343510924_thumb.jpgpost-709-0-58066600-1343510929_thumb.jpgpost-709-0-34299400-1343510934_thumb.jpgpost-709-0-60128200-1343510953_thumb.jpgpost-709-0-56517800-1343510949_thumb.jpgpost-709-0-53489200-1343510938_thumb.jpg post-709-0-66947700-1343510944_thumb.jpg
  • R33 GTR Series 3 Door Trims
    Condition: Immaculate. Not a mark on them, you will not find a better set.
    Price: $500
  • R33 GTR Full Carbon Insert Dash by Superior Auto – incl. drivers door panel insert & h.break/g.box boots in carbon style fabric
    Condition: Used. Overall condition is excellent. Some tiny surface marks here/there nothing you really notice unless you have you face 5cm from it.
    Price: $900
I also have a Nismo GTR dash cluster. Not sure of it's condition yet. Once I do i'll post a price, pretty sure it only has around 70k kms on it.
I’ll have pics in coming days, most of you should know what these look like.
Prices are negotiable if you want to buy more than one item.
Contact via PM.
Condition: Used. Still in very good nick overall.
Price: $450
interested in pics....
but is it able to be used with gtr rear pods?
Pics of diffuser in the first post.
No idea if it'll fit with rear pods.It's hung with several large brackets which could be modified easily enough if you wanted.
Carbon dash is sold at this stage.
  • 1 month later...
High chance you've launched them into the bin, but do you have the stock GTR rear anti roll bar brackets and bushes?
Do you have pictures fitted?
My car has a r34 rear bar on it. So I'm just wondering if it meets up to the rear bar of a r33 then it wouldn't fit my car.
How low was it to the ground? (obvious factor as well, your car height)
I'm highly doubtful it will fit a R34 - the rear ends are quite different in that department. You'd be better off with a R34 one and not really a good gamble to buy a R33 one in the hope it will fit a R34.
The car i'm talking about is a R33 GTR with the complete R34 GTR conversion.
So its got the chassis of a R33 GTR - so the brackets would all fit no problems.
Hopefully the clears it up, so depending on the alignment with the rear bar, it could work.
I'll investigate.
Yeah look I can't say yes or no to that mate.
I can get some pics of it fitted but they most likely will not answer the questions you have. You'd need to compare the bars yourself to see the different areas that might cause issue.
Not trying to be difficult on this, I just don't want to sell it and then you get stuck with something you can't use (and im not going to investigate it). :)
  • 1 month later...
Interested in the doorcards. Have you got the rear trims as well. Thanks
I don't have the rear. Just the fronts.
If you want them let me know - I'm in Goulburn all this coming week if that helps (Not sure where you are from) :)
Hey Ash, you still got the rear diffuser? Would you take $300 for a quick sale? If so please PM me.
I still have it, but no - I won't sell it for $300.
$375 and it's yours.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
