I have Tomei Sump baffle and a mines cam baffle going in, no sump extension tho, also an oil restrictor going in.
Might be alright for a streeter then, just overfill the sump by a 1L.
Edited by wedge_r34gtr
  • Replies 90
Sump baffle and Mines baffles isn't enough.
You NEED a big sump with a Nitto pump. End of story.
exactly, when you have a pump that can pump 65ltrs of oil per minute at 7000rpm, thats more then a ltr per second, how long do you think it would take to empty the stock sump
Hey guys, im looking at getting an N1 pump after what you have all said as i dont have the cash to get the sump and the big pump, what i was looking at doing was replacing the gears in the stock or the N1 pump with billet gears or Reimax gears, i have done some reading and the week point looks like its the gears being crushed under the pressure. Keep in mind my car is running stock boost, stock turbos, and its not going to be a track killer. In your experence would this make a better option or is there another pump that i can go for thats going to be stronger and not require the sump?
http://www.ebay.com.au/itm/RB26-Reimax-oil-pump-gear-upgrade-skyline-gtr-rb25-rb30-rb20-turbo-jdm-/261053373863?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cc7fe5da7
Or would i be better off going with the stock pump and doing gears over the N1 hmmmm, trying to find flow rates for the N1 so i can compair to the nitto pump as i have read on here that they are close to the same flow rate and that defeats ther purpose of not getting the nitto pump.... wish i had the extra coin to do the sump to, sigh
  • 2 months later...
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
