Hi
I'm having a minor issue with cold start when the car has been sitting for a while. I wasnt to worried about it but recently I went overseas for nearly 3 weeks and when I got back the car would only just start and ran horribly for about 5 mins
normally but it will either fire first time and die straight away, then next time it fires up alright and idles perfect
Or
fires up, idles jump up and down about 500rpm (between about 500-1000rpm) a few times then it idles perfect.
I had a FPR laying around so decided to change mine in the off chance something was wrong with it. When I pulled mine out I noticed the fuel was slowly bubbling as if there was air trapped in the rail. Left for a while there was no fuel visible through the hole for the FPR
So it looks to me like over time the fuel drains back through the pump to the tank, but I didnt think this should happen. Was fairly sure the pump has a check valve to stop this happening inside it (I have a Tomei intank pump, same as Nismo)
Car also has 555cc Nismo injectors and 255rwkw. Fuel filter replaced not to long ago (Z201 from memory).
I'm wondering if the check valve in the pump has failed or something, or if perhaps I'm missing something.
Thanks
https://www.sau.com.au/forums/topic/405301-starting-problem-air-in-fuel-rail/
Its a good way to diagnose if its too rich or too lean. If holding the throttle open helps then its too rich on start up. If hinders then too lean.
Makes sense :)
I'll try and remember to do that next time I start it in the morning
can you confirm theres a check valve/anti return valve in the Fuel pump to stop fuel flowing back through it?
I'll have a look tomorrow (if I remember) and make up a little jumper lead to earth it to chassis.
Or I might just do the full re-wire while I'm there
But I have tried priming the car constantly before startup (If I hold my key just before it starts the fuel pump constantly primes) with no improvement
But worth a shot anyway
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
